Cleaning Cylinder Heads
Old Apr 24, 2008 | 04:34 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I got a pair of heads that seem to have some dirt in the ports. I wana get that stuff out before i start up the engine. I dont wana take out the valves and dissasemble the heads. Whats the best way to do this? I was thinking about using a rag and alil bit of oil to wipe the ports out. Any suggestions?
Old Apr 24, 2008 | 04:59 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Re: Cleaning Cylinder Heads
is it "dirt" or is it carbon built up ? if it's carbon I would take the heads apart, no big job really ... especially if you have carbon deposits on the valves, combustion chambers and all ports ... if that's the case.... use oven cleaner in a spray can .. and leave the heads in a cool kinda damp spot (outside overnight is perfect) to let the oven cleaner work ... works absolutely perfect
sweet_87_iroc
Sep 25, 2015 10:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
qz6lwp
Aug 20, 2015 08:10 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
