ticking sound from crane afpr???
Old Apr 25, 2008 | 11:12 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
hey guys i installed a crane adjsutable fuel pressure regulator
also new regulator diaphram.
i also installed new ford 19lb injectors for my 1986 305 5.0 v8 engine
i get this ticking sound and its not my lifters
i thought it was my injectors but after touching the fuel regulator it seems to be ticking there
now could it be because theres a little coin plate inside against a screw that adjusts the pressure against the spring inside and when the car is on the pressure maybe flucuates to a point where the spring inside and bouncing back n forth between the plate and the screw and thats where i get my ticking sound?
and if so is it ok? has anyone else experienced this?
please give your info thanks
and the car runs fine so its not hurting my performance just annoying and i wnat to make sure its not something wrong.
Old Apr 26, 2008 | 10:21 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: ticking sound from crane afpr???
yeah they make noise
Old Apr 26, 2008 | 10:27 AM
Bobby_80s's Avatar
Axle/Gears: no idea
but this is normal and nothing to worry about right?
Old Apr 26, 2008 | 10:54 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
I dont think you have to worry, I got an ticking sound too. they say that its normal to make an clicking sound, I got Accel injectors and Holley AFPR..
The accel injectors clicks ALOT... enoying ...
Lbibb
May 5, 2016 12:00 AM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
wanext
Oct 6, 2015 12:18 AM
meeklay812
Oct 1, 2015 03:46 PM
