Replace Valve Guide Seals??
Old Apr 26, 2008 | 04:46 PM
mito352003's Avatar
Have a 305 that needs vavle guide seal replaced. Is this a DIY job, or is there any special tools required? Thanks Terry
Old Apr 26, 2008 | 05:49 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Replace Valve Guide Seals??
Do a .
This has been discussed to death.
There are several ways to do it. A lively debate always follows.
Yes, you can do it yourself. Special tools are required, but they are not expensive... depending on how you do it...
Old Apr 26, 2008 | 07:43 PM
mito352003's Avatar
I did a search and found the info I needed. Sorry I am new on here.
Old Apr 26, 2008 | 07:53 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
No need to be sorry for being new. I hav`nt done valve seals on my Iroc yet but I did on my `74 El Camino and it was easy. The hardest part of the job is probably going to be getting the valve covers off. Do as Super42 suggested and do a search and take notes. Work up a parts list along with the tools you will need and keep on asking questions, it is the only way to learn anything. I assume your car smokes when first started and until it warms up some, is it also fouling out the spark plugs?
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
