can a lg4 305 run without a.i.r.??
Old Apr 24, 2008 | 10:08 PM
iroc3o5's Avatar
i have shorty headers, a y pipe, a test pipe, and a 3" flowmaster cat back ready to install on my 86 camaro's stock lg4 4bbl 305. the headers are non a.i.r. do i have to worry about my car running poorly without the a.i.r.? do i just remove all the a.i.r. or are there some hoses i have to leave there and plug up??
i cannot wait for my new exhaust, please help!
Old Apr 24, 2008 | 11:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
On how many different forums did you ask this question?
It will run fine without the A.I.R. system. It just won't be street legal.
Old Apr 25, 2008 | 07:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: can a lg4 305 run without a.i.r.??
The AIR system is there to make the cat converter work properly and last a good long while - if you have no cat, theres no point having the AIR system (you weren't street legal anymore when the cat came off, so removing the AIR system too won't change anything as far as that goes)
Old Apr 25, 2008 | 10:39 PM
iroc3o5's Avatar
i just unplugged an electrical connection, the hoses, and vaccuum lines. car ran fine, no code, but did run better when i put my fingers on the vaccuum lines to cap them. so i'll do that. thanks yall
Old Apr 26, 2008 | 08:13 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
be sure to post pictures after you get it all done.
Old Apr 26, 2008 | 09:41 PM
iroc3o5's Avatar
ok no problem. still working on removing the ecm system totally and installing edelbrock carb and intake msd ignition
Old Apr 26, 2008 | 09:51 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Delete
Old Apr 26, 2008 | 10:12 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I think that's a big mistake bro. All you really need to do is pull (disconnect) the O2 sensor, and the ECM will still control the timing electronically for you (you can still run whatever carb you want). If you didn't pull the ECM yet, don't....
iroc3o5
May 16, 2008 08:36 AM
usamuscle892
Feb 10, 2006 02:51 PM
icarus402001
May 20, 2005 07:08 PM
mjdoyle
May 23, 2001 09:44 PM
custman87T/A
Feb 26, 2001 02:37 PM
