biggest valve on stock pistons?
Subscribe
Apr 27, 2008 | 10:24 AM
hi guys whats the biggest valves i can put on stock 89 305 tpi pistons?
i was lookin at heads with intake valve at 1.940 and exhuast at at 1.500
are 1.550 exhuast valves to big?
Reply 0
Apr 27, 2008 | 10:42 AM
Re: biggest valve on stock pistons?
You don't normally need an oversized exhaust valve. The piston's upward movement will always push all of the exhaust gases out of the cylinder. A smaller valve just increases the velocity. I know the 2.02 intake is too big for a 305 bore. When using a 2.02, the common exhaust size is 1.60. Chances are the 1.55 won't be a problem.
The pistons are not the problem. It's the bore size. The tiny bore really limits the size of the valves.
Reply 0
Apr 27, 2008 | 11:51 AM
thx for the info man!
Reply 0
Subscribe
