can someone point me in the right direction
Old Apr 28, 2008 | 08:32 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
I am looking for a crate engine with NON vortec cast heads, roller set up that produces around 400 HP to replace my 87 350.
can anyone help?
all I see is vortec stuff out there
thx
Jeff
Old Apr 28, 2008 | 08:35 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: can someone point me in the right direction
tell me how much you are willing to spend and what type of fuel and i can give you some info
Old Apr 29, 2008 | 12:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Isn't the ZZ4 a non vortec one? It's something like 375HP or so, with 113 heads isn't it?
Check scoggin dickey
sdpc2000.com
Old Apr 29, 2008 | 04:32 PM
jjlabinski's Avatar
Engine: shinny 350
Pace performance says ZZ4 is vortec head engine
as far as how much I am willing to spend money is no object. But I do know what these things cost so reference any of the crate engines you could find at scoggins or pace and thats the going rate.
I want one that will work for me.
jeff
Old Apr 29, 2008 | 04:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
http://www.sdparts.com/catalog/crate...teEngines.aspx
http://www.sdparts.com/catalog/crate...ZZ4Engine.aspx - I'm almost certain this is 113 heads. They say aluminum, and I doubt they mean aluminum vortecs. Call them to double check, but i'm fairly sure on that.
Found from here
http://www.sdparts.com/categories/CrateEngines.aspx
You can't be searching that hard eh? Search for crate engine on jegs or summit too, in order to compare prices. Ohio crankshaft might also do crate motors.
Old Apr 29, 2008 | 05:13 PM
jjlabinski's Avatar
Engine: shinny 350
sonix,
Just got off the phone with Pace and you are correct! They are not vortecs.
But. . .they still dont have what I want. I need heads that are dual bolt pattern for the valve covers and I prefer cast heads over aluminum.
my search continues
I will check out some of the links you sent me
thank you
jeff
Old Apr 29, 2008 | 05:27 PM
jjlabinski's Avatar
Engine: shinny 350
Here is what I need to get replaced
jeff
Old Apr 29, 2008 | 05:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume you're trying to save your TPI base.
Fast Burn heads are pretty hard to beat. By the time you spend the $'s for standard pattern heads that flow as well, you'll have spent as much as it would take to dress up a Vortec base.
Old Apr 29, 2008 | 05:37 PM
jjlabinski's Avatar
Engine: shinny 350
I just posted a pic to kinda show why I need to stay with what I got
Old Apr 29, 2008 | 05:43 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
well why dont you just have a machine shop build u good botom end and bolt some patriot performance heads on it....
Old Apr 29, 2008 | 05:50 PM
jjlabinski's Avatar
Engine: shinny 350
BECAUSE...I just spent 6000.00 for this engine it has never been on the road has about 2 hrs run time in my shop and a bearing went!
I want something with a warranty and something I wont have to pull again just after I install it.
I had the engine built by a local reputable shop who recently went out of business and left me hanging.
Jeff
Old Apr 29, 2008 | 06:47 PM
jjlabinski's Avatar
Engine: shinny 350
Thanks folks I found someone to get me the engine I want....engine factory.com
jeff
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
J0386
Oct 12, 2015 07:46 AM
Hill1513
Sep 19, 2015 04:15 PM
Out-Cast
Sep 11, 2015 08:03 AM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
