Manley valve stem seals 187 heads
Which Manley valve stem seals will work on 187 heads? TBI engine
http://store.summitracing.com/partde...5&autoview=sku
or
Whats the Guide size? LMK. I plan on using these to replace the felpros that arent working. They are leaking and I have more blue smoke than before
Those seals are a press fit on the guides correct?
Thanks!
or
Thanks!
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Manley valve stem seals 187 heads
Kevin91Z works for Manley. You might send him a message. He posts on the SoCal board.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Or buy some from GM. They aren't expensive.
I was also thinking about using the seals that came on LT1s. Im sure they would work.
The GM seals are expensive! $50 for all 16. Then again this would be using the Intake seals on the exhaust, I dont know how that would work out.
It SUCKS this thing is smoking. I shoulda left it as is. Maybe I can get refunded for these felpros.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need to get stock seals. The stock head valve guides are .430", I think. Aftermarket heads are .500" or .530".
ambainb
Apr 25, 2016 09:21 PM
