setting base timing
Old Apr 30, 2008 | 12:57 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
setting base timing
how do i set the base timing on my 85 tpi 350?
Old Apr 30, 2008 | 09:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: setting base timing
That's a great sig line...
Isn't it the same as on the CC-qjet systems? Unplug the ESC connector, set the timing, plug it back in.
Old Apr 30, 2008 | 11:34 PM
im running a tpi
Old May 1, 2008 | 12:39 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
on my 86 you just unplug the ESC connector and set the timing.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
