HELP check engine light rapid blinking back fire>>>>>>
Old May 2, 2008 | 10:06 AM
iroc3o5's Avatar
i have the 86 camaro, lg4. i just had heddman headers (no a.i.r.), y pipe, no cat, and 3" flowmaster cat back put on. the whole ride home, about 15 minutes, car was fine. time to test the new exhaust. so i did a few holeshots, and it sounded pretty good. driving away from my last burnout, the service engine light starts blinking rapidly, motor starts cutting out, and the fasten seat belts light blinked as well. i took my foot off the gas, and camaro idled like normal. put my foot on gas again, same thing. then it went away for a block, then did the same thing once more. i ***** footed it back home, about 2 mins of driving, and it was fine.
what could it be??? ses light went away right afterwards each time. it just blinked rapidly. the fasten belts light came on at the same time, but i was wearing my belt. the old a.i.r. vaccuum lines were plugged, and the plug wires do not appear to be rubbing the headers anywhere.
what could it be??? please help, this is my daily driver.
Old May 2, 2008 | 10:12 AM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: HELP check engine light rapid blinking back fire>>>>>>
Just a guess, but have you checked the alternator? Weird things happen when the alternator starts to go. Everything you talked about sounded mechanical, maybe something to do with your new changes, but the seat belt light makes me think its something else maybe.
Old May 2, 2008 | 10:28 AM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Sounds like something is either losing a ground or something is shorting against something else.
If you just did a bunch of exhaust work, I would start looking at the starter first.
Make sure your wires going to it are tight, and that they are not hitting anything and grounding out.
Can’t remember if it receives power only when the ignition is in the start position, or if it still receives a supply voltage all the time and is only allowed to complete the circuit when the ignition is in start position.
Its just a thought.
Let us know what you find.
Old May 2, 2008 | 10:32 AM
iroc3o5's Avatar
thanks i will check that **** out. just sucks that it is raining like crazy out. the o2 sensor wire is touching the boot on one of the spark plugs. could that be it??
Old May 2, 2008 | 10:38 AM
campin1983's Avatar
Its worth a try to check. One way or the other I'd say the biggest suspect is electrical.
Old May 2, 2008 | 09:31 PM
iroc3o5's Avatar
hopefully it wont rain tomorrow, and i can check out the grounds...
Old May 2, 2008 | 09:40 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Yes. I would imagine that could be deadly to the ECM. It would certainly cause the ECM to reset every time it got zapped.
Old May 5, 2008 | 09:11 PM
iroc3o5's Avatar
i covered the o2 sensor wire with duck tape where it would hit the plug wire boot. havent had the problem since.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
