V-Belt to Serpentine -- Looking for info
Old May 5, 2008 | 11:48 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I want to swap from a V-belt to a serpentine setup on my engine swap (not needed, just wanted). The set up is from a 92 Camaro and my car is an 84 T/A. I know that sometime in the late 80's they moved the AC compressor from the drivers side (like mine) to the passenger side.
So I have two questions. First, will the pulleys on the Serpentine set up fit my old v-belt components without trouble or will I have to buy all new accessories?
Second, will I be able to bolt my Alternator in the AC slot on the serpentine set up?
Thanks for any help!
Old May 5, 2008 | 03:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: V-Belt to Serpentine -- Looking for info
Originally Posted by Ozz1967
So I have two questions. First, will the pulleys on the Serpentine set up fit my old v-belt components without trouble or will I have to buy all new accessories? Second, will I be able to bolt my Alternator in the AC slot on the serpentine set up?
I just did the swap; however, I took the easy route and purchased the GM kit. I don't know if the pulleys are a fit or not, but I'd recommend picking up new--you'll have to replace the water pump anyway since the serp set-up requires a reverse flow. The following link may provide answers to questions you haven't yet considered:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old May 5, 2008 | 06:08 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Originally Posted by JamesC
I just did the swap; however, I took the easy route and purchased the GM kit. I don't know if the pulleys are a fit or not, but I'd recommend picking up new--you'll have to replace the water pump anyway since the serp set-up requires a reverse flow. The following link may provide anwers to questions you haven't yet considered:
JamesC
Thanks James, I appreciate the help!
3rdgenparts
May 21, 2016 11:50 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
