"113" heads ??
Old May 6, 2008 | 12:43 PM
83MonteSS's Avatar
"113" heads ??
I just recieved my heads in the mail. They are bare casting that need full valvetrain. I was wondering what upgrades or mods could be done while I have the bare castings? Im going to get them checked out at a machine shop to insure that they are good to use but what else should I have them do? Im running an LPE 211/219 cam on a 350 1pc rms block with an LT1 rotating assembly. Compression should be around 10:1 with the 58cc on the heads. Any input is appreciated.
Old May 6, 2008 | 01:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Manley valves, and good valve springs.
Old May 6, 2008 | 09:14 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: "113" heads ??
These heads flow very well with porting and make good power and torque.
The hot set up is to use the 2.00" x 1.56" LT-4 sized valves in these heads.
This is largest recomended valves to use on the stock valve seat inserts.
Old May 7, 2008 | 01:36 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: "113" heads ??
Thank you for the recommendation.
Manley 10721-8 and 10722-8 are our street flow series, 1.94"/1.50" with narrow stems for more flow. They will drop right in and work with any street engine without a power adder. If you're going to run nitrous or a turbo you'll want to step up to our severe duty series of valves.
We do make 2.00"/1.56" valves but I have not heard of those sizes working with the stock valve seats. I do know those are the largest valves you can use with these heads, and they are not a direct drop-in, but I have no idea what is required to make those work. 2.02"/1.60" will not work in any way.
You can also use Manley 22410-16 springs and 23652-16 retainers, which will be good for cams up to .550" lift. If you need locks, the 13091-16's are a good 7 degree stock replacement and work with those retainers. Add in a set of 42106-16 3/8" rocker arm studs, and you're in business.
These heads are the casting number for the L98/ZZ3/ZZ4 heads, and you can search this board for "L98 heads" or "Corvette heads" or "ZZ4 heads" to read about the 3 major problems with them. I used those heads for 6 years and have posted the info on here many times.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
