Camshaft Question
Old May 7, 2008 | 04:25 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
Camshaft Question
its time for a Camshaft swap in a 92 RS 305.
is this cam a hydralic roller? or a hyd. flat tappet?
secondly whats the benifit of putting a LT1 Cam in this engine and what kind of idle will i recieve?
lastly. where can i order a LT1 cam and lifter kit.
any help would be awesome!
thanks
again
LUKE
Old May 7, 2008 | 05:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Camshaft Question
Roller.
Yea, LT1 is a good cheap upgrade.
Find those on ebay or the like. Many people with LT1's are yanking their cams to go bigger. Don't need the lifters, you can reuse your existing ones.
No big idle change, but it will have a bit more HP across the board.
Old May 9, 2008 | 10:52 AM
Car: 92 Rs
cool thanks sonix
also, does anyone know how loapy of a cam you can run without the ECU getting confused. thanks or a part# crane, comp etc..
LUKE
Old May 9, 2008 | 11:24 AM
Sonix's Avatar
Car: 1982 Trans-Am
in a 305 TBI engine? I think you need to remain pretty tame. Check on the TBI forum, more guru's specific to those problems over there.
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
