TPI dies in drive, wont restart for a few minutes
Old May 8, 2008 | 07:34 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
This is a recent problem (for 2 weeks). Starts fine, drive around for any short length of time (10-15 min) and engine will suddenly shut down during normal driving. After it dies I turn the key, engine cranks but wont turn over. Try that a couple or three times. Then wait for a minute or two. Turn the key and give some gas and it starts right up and wont give any further problems.
This happens about once a day.
Havent changed fuel filter since summer 06. My TPS sensor is new (2 months ago) with a new harness but wires are rigged (i.e twisted together and not soldered/shrunk). I adjusted the fuel PSI to 46 about 4 weeks ago with an AFPR.
Any thoughts?
Old May 9, 2008 | 11:26 AM
Re: TPI dies in drive, wont restart for a few minutes
bump
Old May 9, 2008 | 11:51 AM
gotay5's Avatar
check injectors resistance
Old May 9, 2008 | 12:57 PM
They are reman'd. I checked a year or so ago and they were all ok on resistance. I will check again this w/e. Anything else?
jklein337
Sep 19, 2018 06:23 PM
apo_bailon15
Mar 28, 2016 05:20 AM
zeitghaist
Aug 18, 2015 07:33 AM
Sanjay
Aug 12, 2015 03:41 PM
