350 TPI blowing oil out valve covers
Old May 7, 2008 | 08:36 PM
Conman1972's Avatar
Hello fellow motorheads,
Hopefully someone has had the same problem and solved it without a motor! I have an 88 Iroc 350 tpi. I bought it already built. It has a small cam and an Edelbrock intake. The valve covers are a stock style cover. When it is ran hard, it blows oil out of the vents in the valve covers. Could it possibly need an additional pcv valve? Would tall valve covers help? It doesn't smoke at all, so I don't think its a wear issue. Any help would be appreciated.
Thank You, Jason
Old May 8, 2008 | 05:04 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
Re: 350 TPI blowing oil out valve covers
it shouldnt have "vents" on the valve covers
im sure you mean its coming out around the pcv grommet or oil cap grommet
check you oil pressures during reving and idle and post them on here.
im sure all your va;ve cpvers need are baffles, but id just get some chrome baffled tall ones if i were you and see if it help,, if it doesnt at least itll look good
i got a feeling this is carbed for some reason
Last edited by Pennocks91ws6; May 8, 2008 at 05:06 PM. Reason: Automerged Doublepost
Old May 8, 2008 | 06:50 PM
Conman1972's Avatar
I guess it's coming from around the oil cap and there is a breather on one side that its blowing out. I'm thinking your right and the valve covers don't have baffles. I'll check it out this weekend and let you know. Its not carbed, still TPI, just aftermarket Edelbrock parts -- suppose to be 375hp.
Old May 8, 2008 | 07:41 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
This usually indicates damaged compression ring/s or piston/s.
Have you done a compression check?
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
