high performance distributor cap and rotor and spark plug wires
Old May 10, 2008 | 10:31 PM
rokinz28's Avatar
i have a 1991 z28 camaro with an automatic 305 tpi. i have stock spark plug wires and a stock distributor cap and rotor. i was thinking about putting high performance parts for the distributor cap and rotor and spark plug wires. i was wondering if it would increase my horse power and torque if i used high performance parts. I also wanted to know if there were any of these parts that would fit just as good as the stock parts.
Old May 10, 2008 | 10:36 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: high performance distributor cap and rotor and spark plug wires
"high" performance plugs,wires,cap,rotor will only make your car faster by weight reduction of the drivers wallet... replace them yes... with stock replacements.... they will work great with your stock engine
Old May 10, 2008 | 11:06 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
"high performance" ignition parts are only needed when the rest of your motor falls in that catagory i.e. high compression, nitrous, forced induction......
Old May 11, 2008 | 08:43 AM
rokinz28's Avatar
Thanks, I appreciate the input. I was thinking the same thing , but a friend of mine told me he replaced his plug wires, cap, rotor and coil w/ MSD stuff and his car got a little faster and his gas mileage improved too (?). The hi perf stuff is over twice as much though, so I thought I'd throw it out here to you guys that have probably tried that already.
Old May 11, 2008 | 08:54 AM
Car: 91 RS
Engine: 350 vortec
that stuff might seem to make the car faster but... that only means that your old stuff needed to be replaced not that you needed performance ignition components
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
apo_bailon15
Mar 28, 2016 05:20 AM
