installing a electric inline pump
Old Aug 27, 2007 | 07:47 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Im going to be swaping a l98 with a non cc carb on it into a cc carb z28 car that has a mechnicle pump my iroc has a electric intank pump regulated down to 6 psi for the carb how would i install a inline pump in my z28 thats equipt with a mechnicle pump? I would ike to keep the stock fuel tank.
Old Aug 27, 2007 | 09:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What year is the Z28 this is going into?
Old Aug 27, 2007 | 09:24 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Re: installing a electric inline pump
84 lg4
Old Aug 27, 2007 | 09:34 PM
five7kid's Avatar
Are you just looking to have an electric pusher, or replace the mechanical?
Most people mount the in-line electric back where the line goes over and in front of the axle.
Old Aug 27, 2007 | 09:37 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well im pulling the 305 with the mechnicle put and installing the l98 which has no fuel pump lobe on the roller cam so that means there will be no fuel pump on the z28 to fuel the 350 the iroc has ai ntake pump and i put the mallory 4309 regulaor on it to keep it at 6psi i would like to use a holley red pump to fuel the 350
Old Aug 27, 2007 | 09:50 PM
five7kid's Avatar
That's it, then. Put it back by the axle.
Old Aug 27, 2007 | 09:57 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
is there only one fuel line running to a 84 lg4 fuel tank how will i have to modify the lines so that the pump gets fuel from the tank?
Old Aug 27, 2007 | 10:05 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
get an aeromotive or holley performance pump.the red pump and the blue pumps burn out after a year or so mebbe 2 i have gine thru 4 pumps in the past 5 yrs, now i just ordered a new pump. just givin my .02
Old May 11, 2008 | 10:30 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I'm doing the same thing with my 84 T/A...though my block has the mount for the mechanical pump, it's not drilled for the pump shaft so I have to install an electric pump. Do you have the summit part number of the one you just ordered? Or the Holley Performance pump you just mentioned? The Aeromotive ones are damn expensive.
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
toronto formula
Nov 10, 2015 06:17 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
lakeffect2
Aug 23, 2015 08:44 AM
