help with 305 performance heads
Old May 11, 2008 | 04:37 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
i have a 305 bored .030 over . has some top end gear. holley street dominator intake mani. 600 cfm edel. carb. hei distributor.
i want to know what kind of performace heads i would be able to buy that will improve the engines performance.
i was scared by some one... i was told that some 350 heads might be too big for a 305... so now im kinda confused.
sorry im a honda guy but im trying to learn the domestic side because i like the import and domestics.
by the way i forgot to mention that i dont want to replace my intake manifold.
so i would need heads that accept my current intake manifold.
i have center bolt valvecovers
Old May 11, 2008 | 07:03 PM
Damon's Avatar
Re: help with 305 performance heads
Trick Flow is about the only company that makes a performance head specifically for 305s that I'm aware of, but they are only offered in angle plug configuration:
http://www.trickflow.com/egnsearch.a...8&autoview=sku
They have versions with the same intake bolt pattern your current centerbolt heads have (87-95 bolt pattern) so you could keep using your existing intake.
World Products also offers a 305-specific head but it's really a stock replacement, not a high performance head, and it's only available in cast iron.
Old May 11, 2008 | 11:33 PM
Simply-305's Avatar
now would i be able to slap a set of performance 350 heads on this thing???
thats my real question. can i interchanged 350 performance heads for stock 305 heads without running into any type of clearance issues?
Old May 12, 2008 | 11:23 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Typically, 350 heads will have too large of a combustion chamber for a 305. Thus the compression would be too low.
You need to use heads that have ~58cc combustion chambers.
Old May 12, 2008 | 11:47 AM
Simply-305's Avatar
ok thanks for the help
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
