best timing
Old May 14, 2008 | 08:06 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
best timing
what is the timing supposed set at on a 82 firebird with a carbed 305?
Old May 14, 2008 | 09:20 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: best timing
6 degrees.
Old May 15, 2008 | 12:31 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Re: best timing
Anyone else?
Old May 15, 2008 | 12:34 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: best timing
initial timing? um id say 6-8 is probably stock play with it some and see what gets u the performance u like, be careful of detonation, i have my 350 at 12 degrees initial ....
Old May 15, 2008 | 12:38 AM
squeeezer's Avatar
Car: 5 cars
Re: best timing
do as much base timing as your starter motor will let you get away with
i have a 406 in my camaro that has a base timing of 29 deg and only 5 deg mech advance
Old May 15, 2008 | 12:43 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Re: best timing
Thanks guys I try that tomorrow
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
