Which balancer do I use?
Old May 16, 2008 | 08:13 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'm replacing my worn out 305 with a 350. Both are 1 piece seal blocks. The 350 came with a larger balancer than the stock balancer that was on the 305, does it matter which one I use? Will I run into any interfearance problems with the larger balancer hitting the k member or anything? Thanks.
Old May 16, 2008 | 08:47 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: Which balancer do I use?
My understanding is that SBC balancers are interchangeable. I hope so, anyway. I just put the balancer from my 305 onto my 350. But it's still on the stand, so somebody please speak up if I'm getting ready to screw up.
Old May 16, 2008 | 09:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's going to depend where the timing mark is on the balancer and where the pointer is on the front of the engine. If the pointer is close to the small balancer, then it's not going to fit with a larger balancer. If one balancer has the timing mark roughly at the keyway and the other is part way around then you'll never be able to time it without the proper pointer.
Buy a new replacement balancer. They're not that expensive. How old is that old balancer? They don't last forever.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
