Difficulty Adjusting TPS Sensor
Old May 17, 2008 | 01:57 PM
mouthforcombat's Avatar
Car: '86 Iroc Z
My situation: I bought a new Throttle Position Sensor and installed it. Even after clearing the ECU codes, I'm still getting a 23 (TPS), and only that code, no others. When I accelerate decently hard, the check engine light goes away... Then when I start braking, it instantly comes back on. I bought a voltometer and I am getting a little over 1 with closed throttle, and it's supposed to be around .46-.53 and at wide open throttle I'm getting around 6 when supposed to be at 5. Any ideas? I am sure this is the reason my idle is so low (500-600 at a stop, when motor is warm).
Old May 17, 2008 | 02:48 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Difficulty Adjusting TPS Sensor
did you adjust it any or just install it. the '85-'89 had adjustable throttle position sensors. if yours doesn't have slots for adjustment, then you have the wrong one.
500-600 rpm idle when warm is fairly normal
Old May 17, 2008 | 04:05 PM
Car: '86 Iroc Z
It adjusts in a sense that if you loosen the two screws holding it, you can movie it up, down, forward, or backwards...
Old May 17, 2008 | 05:03 PM
87zjeff's Avatar
that is how you adjust it. you need jumper wires and the volt meter hooked up to adjust it.
https://www.thirdgen.org/tpimod2
this is a link to a tech article on this sight explaining how to adjust tps and iac.
J-money
Jan 4, 2019 09:45 AM
lakeffect2
Sep 7, 2015 03:52 PM
dimented24x7
Sep 6, 2015 03:51 PM
willyjoejr
Sep 3, 2015 09:26 AM
