Buying New Engine: need suggestions!
Old May 18, 2008 | 07:37 PM
Chris51173's Avatar
Car: 1984 Z28, 1989 RS Camaro
Engine: V8 305 HO LS9, V6
1989 RS
Transmission died so I am thinking aout getting rid of the V6 and putting a 350 in. Where is a good place to buy one and what kind of prices am I looking at for a new engine and trans?
thanks!
Old May 19, 2008 | 09:52 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Buying New Engine: need suggestions!
Might wanna consider buying a v8 parts car with hopefully a good eng or tranny you can use. You're going to wind up needing all sorts of stuff you probably haven't thought of to do a v-6/v-8 conv (i.e. exhaust sys, intake, ign, ecm, ecm wiring harness, cooling sys, driveshaft?, accessory brackets, etc). That nickle and dime stuff really adds up. I went from a 305-CFI to a 350-TPI and needed a lot of stuff off the parts car.
Old May 19, 2008 | 03:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Depends on what you want really. Any 350 can be swapped in, just depends on your wallet. I had 305, wanted a 350, but didn't have much budget - picked up a used rebuilt 1969 350 with mild cam for $800 carb to pan. Went carb to avoid the chip programming, so it's all old school now - if you're emissions will allow, carb is the easiest way to go. You'll need a different tranny for a 350 anyway. And motor mounts will have to be moved. I'm not sure what else - there will be a sticky in the swap section on V6 to V8.
Old May 19, 2008 | 03:57 PM
Chris51173's Avatar
Thanks guys
ChristinaMarie
Sep 11, 2015 06:28 PM
64goatman
Sep 9, 2015 01:09 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 8, 2015 11:28 PM
Jk_Under
Sep 8, 2015 08:13 AM
