Hood Clearence Question
Old May 18, 2008 | 08:45 PM
ThermalTrans's Avatar
Car: 85TransAm,97Firebird(Formula)
Engine: 305 5.0L,5.7LTI
Transmission: 700R4,Tremec 56
Clearence question
I was going to be getting an Edelbrock Performer Air Gap Intake Manifold and I know that the clearence can be an issue with Air Gaps and was wondering if anyone knew if a stock hood could handle it without having to manually modify the hood.
Old May 18, 2008 | 10:10 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Hood Clearence Question
yes, my son-in-law ran a holley street dominator on his with no probs., later jimmy
Old May 18, 2008 | 10:33 PM
Yeah but was he running an Air Gap. I was curious if the hood held enough room for the extra space needed for the Air Gap in the manifold.
Old May 18, 2008 | 11:12 PM
Nsomnia's Avatar
I'm running a performer with a 10x2 aircleaner and it only has ~1-1.5 inches of clearance, the air gap is very similar right? im gonna say it will be verrry close but should fit.
Old May 19, 2008 | 02:40 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Performer and Performer Air Gap are the same height, and both are shorter than my RPM Air Gap, which fits under my hood (barely).
Old May 19, 2008 | 09:12 AM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
I am using an RPM Air Gap and I had to add clearance to my hood.
I heard of guys running real short filters and getting away with it under hood, but I didn’t want to sacrifice airflow.
I did wonder if one of those formula hoods with the budge in them would have worked, but I never tried it.
Let us know what you eventually choose to do.
Old May 19, 2008 | 01:19 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I was running the reg. rpm intake and in order to have that fit under hood i had to buy the edelbrock low profile air cleaner...part number 1206
Now I got the rpm air gap....no way thatd fit.
Old May 19, 2008 | 01:50 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Im running a RPM Air-Gap with a dropbase air cleaner under a stock 92 camaro hood with blisters. The filter is only 2" but I am running a Holley Street hp without a choke horn.
Old May 19, 2008 | 01:59 PM
SteelTownMadDog's Avatar
People think there's a difference in height between the air gap model and the old style....THERE ISN'T. Go look on the Edelbock site. Both Performer RPM and RPM air gap are the same height, same with the regular Performer.
Old May 19, 2008 | 02:23 PM
Huffs_91_RS's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
Ive got the Performer RPM Air Gap with a drop base n a 3 inch air filter n it cleared my stock hood. The screw down on the air cleaner had a mark on the insulation under the hood where it was up into it. I see no problems with clearance.
Old May 19, 2008 | 02:44 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
https://www.thirdgen.org/forums/afte...?highlight=L88
https://www.thirdgen.org/forums/tech...highlight=l-88
its not a out of the box bolt on.... but....
Some modifications are required, but this L-88 air cleaner base gives the most clearance.
The performer Air gap manifold is approx .3" higher than the performer.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
