ls1 heads on an old 350?
Old May 20, 2008 | 11:18 PM
fbirdroller's Avatar
Car: 1986 camaro z28
Engine: vortec 5.7
can i put stock ls1 heads on a 79 350 out of a z28? if i can do that, is it worth it?-what effect will it have?
Old May 20, 2008 | 11:29 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Re: ls1 heads on an old 350?
No I don't think those's will fit.
I am pretty sure a LS1 is completely different from a old 350
Old May 21, 2008 | 01:32 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Not a chance. Thats kinda like trying to put a small block chevy head on a Honduh 4 banger. LS block is totally different from a classic chevy block.
But then again........somebody DID put LS1 heads on a Ford 351.
http://460ford.com/viewtopic.php?t=18923
Old May 21, 2008 | 01:52 AM
Guest
Guest
Posts: n/a
Its not impossible, but for what it would cost... better to forget that idea.
Old May 21, 2008 | 09:22 AM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
ls1 motors are really great motors, but take advantage of your old school design my friend. You can get better flowing heads for less. AFR heads are really good. They did a test on a stock 5.0 mustang, they through on some afr heads and just with the heads it made 100hp. i don't recal the valve sizes or anything but they are among the best heads. or you can go super cheap with a pair of vortec heads that will give you 40hp, and when combined with a bigger cam and intake 60-70hp isn't unreasonable.
Old Nov 27, 2008 | 02:43 PM
nd4spd42085's Avatar
Car: Formula/RS
Engine: 5.7L/60 degree
Transmission: both 700r4
Axle/Gears: 2.73 lsd and 3.23, respectively
It's not possible, already explored the idea... totally different design... nothing from 1st, 2nd, and 3rd gen motors are interchangeable.
Old Nov 27, 2008 | 04:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Except roller lifters and crank bearings.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
