Valve Tap, Is it too late?
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
For the longest time I could not figure out if my 84 Z28 Carbed 305 H.O. was suffering from an exhaust leak or a valve tap. The tapping remained after I tightened the passenger side headder bolts on my edelbrock headders. The tapping comes in and out at all different engine temperatures from cold to operating.
Assuming it is a valve tap, it has gotten worse I havent had a chance to really do anything about it until now, i have driven the car for probably over a year, mabe 10,000 miles with this problem. but like I said it doesnt do it all of the time.
If i am going to go through the trouble of removing the valve covers to tighten the all 16 valves down.... will it even fix the problem, or did I wait too long. If so what should I do, would buying replacement rockers solve this... or should I just leave it alone and put thicker oil in for now... I only need 1 more year of driving with this car before it goes into storage for a long time.
Transmission: 4L80E/4L80E
Has the engine been abused or neglected? Regular oil changes?
You might try changing the oil/filter and using one quart of ATF in place of one quart of oil. If the problem is a dirty/gummed-up lifter, the ATF may clean it up.
If it is an adjustment problem, don't just tighten all of the rockers - adjust them properly.
It could be a bad lifter, worn cam lobe, worn rocker, worn pushrod, or pulled rocker stud. Or, a backed-off adjustment nut that has lost its self-locking capability.
Hotrodboba400
Dec 10, 2019 07:07 PM
355tpipickup
Sep 13, 2015 11:35 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
