Belt Problem
Old May 22, 2008 | 11:52 PM
musclecars90's Avatar
Car: 1986 Iroc Camaro
Engine: 305 5.0L
Transmission: 700 R4
Belt Problem
I have an 86 iroc 305 lb9. No matter how much i tighten the belt for the heater and the a/c it squeaks when i turn it on wen i step on the gas or when i rev the engine. And its the second new belt. Does anyone know the problem i would appreciate it thank you.
Old May 23, 2008 | 01:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Belt Problem
Belt for the heater and a/c?
Is this car a v-belt or serpentine setup? I'm guessing v-belts?
What all is driven by this belt? Is one of the things a bit tight? ie. remove belt, do they all spin easily?
Try removing the belt, and grabbing some 180g sandpaper, and roughing up the area where the belt sits in the v-belt groove. That will help it hold well.
But i'm guessing one of the accessories is starting to die (seize).
Old May 23, 2008 | 07:48 AM
RicksIroc86's Avatar
Car: 84 camaro z28
Re: Belt Problem
yea and also check to make sure all the bolts are in. on mine i forgot one of the alternator/ps pump bracket bolts so it was getting pulled causing the side of the belt to squeak on the side of the pully. so check that maybe
Old May 25, 2008 | 12:01 AM
Engine: 305 5.0L
Re: Belt Problem
i was looking and saw that i am missing a bolt from my air pollution underneath my alternator thanks for the help i just need to find a bolt that will match up with that. Since i bout the car used its been doing that thanks
Old May 26, 2008 | 06:00 PM
Car: 84 camaro z28
Re: Belt Problem
ok good glad i could help. that just happened to me but my bracket broke(as would yours eventualy) and its 101$$$ for a new brackit.
1992 Trans Am
May 10, 2023 07:19 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
