cause and effect
Old May 26, 2008 | 12:06 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
cause and effect
Looking for additional opinions:
Would you think having two completely wiped out cam lobes each one on a different cylinder and different valve (one intake the other exhaust)cause an engine not to run and just sputter a little bit while cranking?
just thinking bout stuff
Jeff
Old May 26, 2008 | 08:43 PM
Vader's Avatar
Re: cause and effect
It's possible. If the wiped exhast is on a cyinder that fills with fuel, ignites, then exhuast back into the intake when the intake valve opens, not much fuel mixture might get into other cylinders. The wiped intake would be less of a problem.
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Damon
Sep 26, 2015 04:29 PM
James Sutton
Sep 23, 2015 01:56 PM
billybob6110
Sep 23, 2015 01:30 PM
ASE doc
Sep 22, 2015 03:13 PM
