EGR Valve location
Old May 23, 2008 | 01:57 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
EGR Valve location
So im just wondering where on my 305 TBI is my egv valve so i can unplug it. I need to pull my TBI unit and clean it out but I got a check engine code tge other day and the scanner told me it was my EGR valve and told me not to drive it. I get crap gas mileage, so could that be why? I was told to unplug it and my engine will run better without it. Could you show me pics of where it is located or tell me so i can fix this problem.
Old May 23, 2008 | 03:08 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: EGR Valve location
Remove the air cleaner assembly. On the passenger side of the engine, right behind the throttle body is the egr valve. Looks like a mushroom. Disconnect the vacuum line, remove the two bolts and take the old unit with you to the nearest auto parts store. They'll help you with a replacement. Read the new directions closely, match the shim (per instructions). Replace the egr unit. Easy project.
Good luck
Old May 23, 2008 | 06:48 PM
Engine: Vortec 357
Good luck
ok thanks. I pulled my cat off so in reality i have no use for the egr valve correct? i plan on putting a high flow cat on soon so ill just replace it. What is shim by the way?
Out-Cast
Sep 3, 2015 09:05 PM
Thaney9
Aug 29, 2015 03:16 PM
injdinjn
Aug 28, 2015 12:51 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Out-Cast
Aug 17, 2015 10:57 AM
