305 Heads
Old May 23, 2008 | 01:58 PM
Cash25's Avatar
Car: 1986 Iroc Z-28
Engine: 5.0 305 TPI
Axle/Gears: Stock
305 Heads
I have a 91 Camaro RS 305 5.0L, looking for suggestions on which heads to place on this motor. Thanks
Old May 23, 2008 | 10:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 305 Heads
Hey Robert,
What are your plans for the car in the long run? Heads are big $, might as well get the ones that will suit you best eh?
Any other upgrades so far? Exhaust, cam, etc?
Any other upgrades planned to go along with the heads? Or soon after?
Budget for this modification? How deep are your pockets?
Old May 24, 2008 | 09:13 AM
Cash25's Avatar
Car: 1986 Iroc Z-28
Engine: 5.0 305 TPI
Axle/Gears: Stock
Re: 305 Heads
Nothing has been done to the engine, from the Y-pipe back on the exhaust I bumped it up to 3" piping. I know for the 305 the top end is dragging the engine down. I been reading alot of articles about people grabbing almost 3 to 400 Horses out of a 305. I'm about to rebuilt mine, just like to try and get alittle more power out of it.
Old May 24, 2008 | 11:57 AM
afida15's Avatar
Re: 305 Heads
well if your about to pull your motor out anyways then i would just spend the money on a 350. just find a old 350 at a junkyard that has a good crank in it well one that you can use and get machined. all 305 and 350 parts are almost the same price when it comes to pistons and all that. im just saying go 350 cause you want to do heads and those arent cheap so might as well put some heads on something thats worth it
Old May 24, 2008 | 12:19 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: 305 Heads
Vortec heads and a Vortec type manifold should work nicely.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
