Belt fraying problem
The new belt on my 90 RS is turning into rubber powder thats gettin everywhere on the front of the engine. The belt is clear of everything
and belt is the right one and a quality belt. Fraying is mostly on the outside of the belt. The last belt I had did the same thing I figured it was the belt. Help me out.
Re: Belt fraying problem
Only time I encountered that it was on the INSIDE (ribbed side) of the belt. The distance between the tensioner pulley and the water pump pulley was very close and it would make very slight contact sometimes at high RPMs, covering the intake and front of the motor with little rubber pieces.
Having the outside (flat side) the belt coming apart sounds different. The only 2 pulleys that contact the outside of the belt are the tensioner pulley and the water pump pulley.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
db057
Aug 11, 2015 10:11 PM
