no oil to rockers!
Old May 24, 2008 | 09:26 AM
jabz28's Avatar
Car: 84 z28
Engine: 400 sb RIP down to a 350
Transmission: turbo 400
Axle/Gears: posi 373
no oil to rockers!
i got a running 350 and deciding to do a gasket rebuild, threw it in my other cam, new oil pump etc, but kept the valve train cause(good cam,mech rollers,etc) it was nice, only needed to be cleaned up a lot! i was planning on getting this motor running which it does, and drive it everyday and build the motor i really want overtime in my garage. only problem is it runs fine but there is no oil to the rockers, hooked up a new mech guage and i got 60 psi, any ideas? going outside to take push rods out and clean them, but not all 16 would be clogged. anyone have ne ideas?
Old May 24, 2008 | 09:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: no oil to rockers!
How long did you let it run before shutting it off?
It could take as long as a minute before oil reaches the rockers on a fresh build. I was getting worried on 1 of my builds due to that.
Old May 24, 2008 | 10:33 AM
jabz28's Avatar
Car: 84 z28
3-5 minutes or so, then trying to diagnose it poured a half qt over them so they wouldn't be dry gave them another min.I turned it off after that cause i didn't want them to burn up
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
