pulled codes and ......
Old May 24, 2008 | 10:10 AM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
well my car was been getting a little hard to start when its cold and running rich so i pulled codes this morning and i found quite a bit out with whats going on ......54 Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module....23 Low temperature at manifold air temperature sensor OR Throttle position sensor error.....32Fault in barometric pressure sensor circuit OR Fault in exhaust gas recirculation valve diagnostic switch OR Fault in electronic vacuum regulator valve..... my question is where do i start?....i gonna put relay and check fuel pressure but then what?
Old May 24, 2008 | 11:11 PM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
Re: pulled codes and ......
anyone?
Old May 24, 2008 | 11:22 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
unhook battery for five minutes rehook crank and drive then recheck codes and go from there. those codes were probably set at different times,later jimmy
chazman
Aug 28, 2018 03:25 PM
C409
Sep 1, 2015 03:42 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
