just checking - 350 with 5 speed - starter
Old May 24, 2008 | 06:31 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Just cranked my TPI 350. I used the 5 speed that was behind the 305.
I am getting a little grinding at the starter when I first hit the key.
Will the starter for the 305 5 speed work on the 350 (yes it does bolt on)? Do I need to modify anything other than possibly shims?
flywheel was same tooth count and size as flexplate. 700r4 starter doesn't fit the 5 speed bellhousing. Had to use the smaller starter from the 5 speed.
This seems to be the only problem and troubleshooting so far with the swap.
Old May 24, 2008 | 06:50 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: just checking - 350 with 5 speed - starter
as long as you are using all 153 tooth stuff you shouldnt have any problem with compatability you just need to play with some shims
Old May 24, 2008 | 06:51 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I would try some putting shims in. if it bolts up and turns the motor it should work.
Old May 24, 2008 | 07:49 PM
Nsomnia's Avatar
Yup shims. My last 350/t5 build needed a 1/16 and 1/64
BRoss99
Aug 10, 2025 05:08 PM
mhatfield 14
Oct 24, 2015 07:48 AM
milk
Aug 10, 2015 06:26 PM
86Base
Aug 8, 2015 01:34 PM
