starter question?
Old May 25, 2008 | 03:44 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
starter question?
my starter is acting funny and its brand new. turn the key and the motor will turn over like once then the stater just spins. i think the bendix is not staying engaged. its actuated by the solenoid right? upon removal the bat cable to the solenoid was loose do you think this could cause my prob? please help
Old May 25, 2008 | 04:46 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Re: starter question?
A loose cable at the starter will not cause the starter to stick. You could have got a bad starter. When it sticks is the starter frewheeling or does it start the vehicle and continue to spin?
Old May 25, 2008 | 08:04 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
it will turn the motor once or twice and then the bendix will pop back in the nose cone and continue to spin. the starter gear will not stay engaged to the flywheel. took the starter to advanced and tested good. motor is about 11.0:1
Old May 25, 2008 | 09:30 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Did you shim it correctly?
Old May 25, 2008 | 10:04 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
yep tried dif shims same problem!!! i bought a new starter installed it with a .040 shim and it started right up. stupid auto z parts
Old May 25, 2008 | 10:32 PM
jv9999's Avatar
Engine: 5.7L/350
Yea, that's the problem with "rebuilt" auto parts. Hang on to that receipt.
Old May 26, 2008 | 05:36 AM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Transmission: 700R/700R
Axle/Gears: 3.42 Posi/3.27 Posi
I had the same problem with a AZ starter since these starters are a b**** to replace I spent the extra money and got a high torque mini from summit and it works great.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
milk
Aug 10, 2015 06:26 PM
