Running lean then no spark
Old May 27, 2008 | 12:07 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
ok guys, the car started running lean (smelled like it anyways), then was left ideling for 5 min, was fine, smeeled a little lean, then driving home it just shuts off real gentle, i barely even noticed. pushed it home, lt it cool off (was running 150 degrees, gotta love a well tuned efi engine, didnt wanna burn myself working on it), went to start it, cranked, fired once that was it, did that once more, then it just turns over and over, its getting fuel i can smell it with the plugs out, but no spark. the security light comes on when i put the key to run, but shuts off after 5 seconds or so, and vats is bypassed in the ECU, and i hardwired past the vats module in the drivers kick pannel. the security light never used to come on at all. i checked spark, and there is none. new plugs, wires, dizzy (accel), coil (gm blaster), all within 6k miles, all fuses are good. i need some ideas, because im outta them. thanks - alex
Old May 27, 2008 | 11:04 AM
Beaches92's Avatar
Re: Running lean then no spark
what does it smell like when its running lean?
Old May 27, 2008 | 03:03 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
kinda like burning rubber a little bit, the car just smells hot, my neighbor whos a old car guy said it smelled lean when i got home (pushing it for 2 miles )
eightsixseven
Dec 16, 2024 01:50 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
92camaroJoe
Aug 13, 2015 06:07 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
