Ticking/Clicking Sound Coming from the Engine
Old May 27, 2008 | 10:56 AM
ruberbanman126's Avatar
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
My dad an I did a full tune up this past weekend. We replaced all the plugs, wires, cap and rotor with AC-Delco parts. At first the rotor was not pushed down all the way and made a strong ticking noise, we fixed that and it still made the noise. The rotor was rubbing against the top of the cap. We put the old cap and rotor back on to see if it would do it, and it did, but they were not rubbing this time. We noticed that the distributor shaft was moving up and down a little bit, is this the problem. What else could the sound be?
Any and all help is appriciated.
Old May 27, 2008 | 11:07 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: Ticking/Clicking Sound Coming from the Engine
Is this something that has always been there? The injectors would normally make a ticking sound when they fire. Try to narrow down where the ticking is coming from. It is normal for the distributor to move up and down some, but not side to side. You can try to use a piece of rubber hose as a statocope to narrow down where the noise is coming from.
Old May 27, 2008 | 12:00 PM
i think it is coming from the distributor, and also, the tach is going crazy, could i have bumped a sensor or something that would make the tach do that?
Old May 27, 2008 | 01:45 PM
I fixed it, numer 6 cylinder was unpluged at the spark plug.
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
