Question about stroking to 383
Old May 27, 2008 | 06:29 PM
TAftw's Avatar
Since the compression ratio is increased on a 383 stroker, would I have to run race gas or something with higher octane?
Old May 27, 2008 | 06:43 PM
ccook-92-305's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R4 w/transgo 700 shift kit
Axle/Gears: 3.42 posi
Re: Question about stroking to 383
depends on where you're coming from on compression. It will only bring it up about 6 tenths of a point so if ur compression to start with was 9:1 or 9.3:1 you'll be fine with the higher octane pump gas. It varies from who you talk to but most people say that 10.5:1 is all the more compression you want on iron heads with 92 octane pump gas. so going off that you would be fine even if you were 9.8:1-9.9:1 or so on compression with the 350. You could also always swap ur heads out to some aftermarket ones with bigger combustion chambers.
heres a calculator you can play with for compression
http://kb-silvolite.com/calc.php?action=comp
good luck
Old May 27, 2008 | 06:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
CR is nothing but the total BDC cylinder/combustion chamber volume divided by the total TDC cylinder/combustion chamber volume. Just choose the TDC cylinder/combustion chamber volume so that the CR comes out at a reasonable level.
More dish in the pistons produces better results than more combustion chamber volume in the heads. Also, aluminum heads can handle/need more CR than cast iron heads.
Above all, keep the quench height in the .040" range - do not fiddle with quench height to change CR.
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
