Motor Mounts
Car: Camaro
Engine: 350 .40 over
Transmission: TH400 TCI
Motor Mounts
Anyone ever changed motor mounts on a 84 H.O the bolts that hold them in have nuts on the back of them the nuts are in the crossmember Joined: Mar 2000
Transmission: 4L80E/4L80E
I realize you haven't been on the Board long, but a
will provide you with the necessary information.
'82, '83, '85, ... '91, '92; V6, V8, I4; HO, base model; doesn't matter. Same situation, nuts inside the crossmember where no man has gone before. . .
will provide you with the necessary information.'82, '83, '85, ... '91, '92; V6, V8, I4; HO, base model; doesn't matter. Same situation, nuts inside the crossmember where no man has gone before. . .
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
