Belt diagram for 87 Bird
Old May 28, 2008 | 05:50 PM
defaced's Avatar
Car: 1987 Firebird Formula
Engine: 355
Axle/Gears: Posi, 3.23
Hey guys, I'm throwing in a 350 from a truck and I removed the A/C and the smog pump and my car doesn't have a belt diagram on it anywhere. My pulley on the crankshaft has a serpentine and then two accessory v-belts. Just trying to find a diagram for this car to see if I need to have delete pulleys for the smog pump and the a/c. I'm not sure what the accessory belts were used for because there weren't any belts on the car when I pulled the 305 out. I searched but all I was able to find were diagrams for the serpentine diagram, none with the serpentine and the 2 accessory belts.
Any help would be greatly appreciated. Thanks guys.
Edit: In case there is any confusion, the crankshaft pulley with the serpentine and two other belts came off of the 305, so that's what was originally in the car when I got it. When my 350 was rebuilt I had forgot to mention that pulley so they put the crank pulley from the truck on there which is only a serpentine. So could I get away with using that serpentine pulley since I took the a/c and smog pump off? I guess what I'm trying to really figure out is what the v-belts were used for.
Old May 29, 2008 | 05:57 PM
defaced's Avatar
Engine: 355
Re: Belt diagram for 87 Bird
Nobody?
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
kitt23
Sep 26, 2015 07:48 PM
