Roller rockers on a 276,000 mile stock 305
Old May 28, 2008 | 06:37 PM
black1990RS's Avatar
Car: 1990 camaro RS
Engine: forged 383,8.7;1 200hp nitrous
Transmission: t56 6 speed
Axle/Gears: quick perfomance 9 inch with 4.11s
if i put proform roller rockers and roller lifters is it gonna hurt my bottom end or will it eventually break in,,,,
Old May 28, 2008 | 08:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Roller rockers on a 276,000 mile stock 305
Why roller lifters? You already have roller lifters.
You can put on the roller rockers. Won't really do much either way.
Old May 28, 2008 | 10:55 PM
Car: 1990 camaro RS
it wont add any power or anything like that
Old May 28, 2008 | 11:23 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Ok, ask yourself this.
First off, it's a 305. Second, it has almost 300,000 miles on it. Is it really worth dumping ANY money into other than maintenance?
Save your money for a new engine, or you're just going to throw it away.
Old May 28, 2008 | 11:46 PM
Car: 1990 camaro RS
well i have allready dumped a bunch of money into a new engine a 350 bored over, medium cam hydraulic roller rockers and lifters, camelback heads the works,,,,,but i am afraid to pull out the 305 it is still running strong,,,,
Old May 30, 2008 | 10:25 AM
Sonix's Avatar
Car: 1982 Trans-Am
Then just wait until it dies. Don't buy parts for it. Just take the "hydraulic roller rockers" from your new 350 and put them on.
Old May 31, 2008 | 02:59 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Roller rockers requires machining for guide plates..... removing the heads, and spending more money, and it won't make much of a difference.
Old May 31, 2008 | 03:28 PM
Stephen's Avatar
Car: 87 GTA
#1, I'd just put them on the 350 BUT....Don't let the "305 haters" bother you.... 310cui w/356hp Lots of 350 owners just wish they had that...Yes, more cui = more hp, but a 350hp 310cui is nothing to sneeze at!
Old May 31, 2008 | 05:14 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
There is no point in messing with a engine with that much mileage but there is nothing wrong with 305s. If you put vortec heads and a decent cam on a 305 you can get some good street HP numbers.
Old May 31, 2008 | 07:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Wait, what? No they don't.
Old Jun 2, 2008 | 09:52 AM
doc221978's Avatar
Car: '81 Z-28
I have always used guide plates and hardened push rods with rollers. I was always told it was necessary, but never understood why. The roller tip goes on the valve... not the rod. I thought i was told that for stability reasons. I stand corrected. I'm only using slotted and stamped stockers.
Old Jun 2, 2008 | 10:05 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
You only need guide plates if you are installing non-self aligning rockers.
Leave your 305 where it is. When it does die, simply have the new 350 ready to drop in its place and be prepared to tune.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
