preoil problem
Old May 29, 2008 | 03:19 PM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
preoil problem
Hi,
today finished my lg4 assemble. then tryed to preoil engine. I rotated oil shaft by drill during few minutes, but oil came out only on one rocker, there were not oil leakage on lifters, but while rotating it came huge oil stream from block rear wall to distributor shaft.
what can be my problem
ps I use high volume oil pump, trickflow roller lifters (not pumped yet).
Old May 29, 2008 | 07:02 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: preoil problem
Originally Posted by Tightenloop
Hi,
You need a primer with a sleeve to get oil to the top end. Just using a rod won't do it.
Old May 30, 2008 | 07:57 AM
Car: Camaro LT
Re: preoil problem
OK,
also finded similar topic
https://www.thirdgen.org/forums/tech...ne-no-oil.html
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
