What order for piston rings 87 350
Old May 29, 2008 | 10:37 PM
xxxbubba4life's Avatar
anyone got a pic of a 350 piston with the rings installed to show what the layer order is?
the oil ring is on bottom with its two holding rings on either side of it, and the top two rings are the compression rings. these are possed to be at 180* from eachother, and 90* from the oil ring. and the oil ring holding rings are possed to be at 45* from the oil ring seam, and 90*from eachother. so no overlap of seams. this sound right?
thanks
Old May 30, 2008 | 07:51 AM
Re: What order for piston rings 87 350
anyone know?
Old May 30, 2008 | 10:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oil ring at the bottom, then the second ring, then the top ring.
The orientation (how they are aligned, rotationally) doesn't make any difference at all. They rotate in the engine while it's running, so however you set it up, will change as soon as you flick the key. That's like bolting on your wheels so the air fill stem is "up", thinking it'll make it easier to add air next week.
Old May 30, 2008 | 10:31 AM
ok thanks man thats what i thought... and yea yer right the position don't make any difference....
Mickeyruder
Sep 2, 2015 02:45 PM
Eric-86sc
Aug 24, 2015 09:01 PM
LT1Formula
Aug 20, 2015 09:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
