Roller Timing Chain
Old May 30, 2008 | 09:51 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Roller Timing Chain
I am going to put a 94 LT1 in my 86 Camaro, apparently this is the crappe model, or the one no one likes...because there are no direct fit Roller timing chain kits for it...the GM one requires extra parts that cost more money, and Lunati makes a set but its for 92-93 LT1s...now my question....
If i was to just use a roller CHAIN would it work on the stock gears for the timing chain on my 94 LT1? just the chain not the gears or anything...
Ox
Old May 30, 2008 | 10:04 AM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
Re: Roller Timing Chain
When I changed stock timing set to some double roller setup in my 87' 305 sprockets was totaly different.
Old May 30, 2008 | 12:14 PM
timespy's Avatar
Car: 91 RS Convertible
Engine: Soon to be swapped
Transmission: Memphis performance 700r4
Axle/Gears: Soon to be changed
Look for a company called s.a gear. they are in bridgeview illionois. I dont know the number, but im sure they will have the double row, adjustable, roller timing chain and gears for your motor.
Vintageracer
Jan 10, 2020 05:33 PM
junkcltr
Aug 2, 2019 11:12 PM
MY87LT
Aug 17, 2015 08:43 AM
BrianI
Aug 9, 2015 11:52 AM
