heads
Old Jun 4, 2008 | 03:05 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
heads
ok i have a set of corvette heads #113, these heads are stock with 0 miles. they came off a zz4 crate motor. I heard some rumors they will fit onto a 305, which i have. now the 305 is brand new, 700 miles, bored 0.030 over. i think its a 350 cam in there now, but if i was to put these heads on it the cam would change and i would be adding tpi. does anyone have any experience or info on this? this idea is not set in stone, please no comments on oh its a 305 blah blah blah, i cant afford a 350 right now and i would like to retain the 305 because it is stock to the car. Thanks
Old Jun 5, 2008 | 10:31 AM
nascar2496's Avatar
Engine: 305 tpi
Re: heads
any ideas on power or if they will fit ?
Old Jun 5, 2008 | 11:17 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: heads
You need to find out what size valves and combustion chambers (cc's)the new heads have.
Old Jun 5, 2008 | 01:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No need to "find out". They have 58cc chambers, 1.94"/1.50" valves.
They will fit. Since the heads are aluminum, which transfers heat more readily than cast iron, it will be an effective lowering of compression on a 305. Remember, those heads were used on a 350, and the 350 had 64cc chambers when cast iron.
Exactly what "350 cam"? There are a bunch out there, and many are worse than 305 cams. Need more specifics.
Most likely you can bolt the heads on and go. Should run a little better than stock 305 heads with cam & exhaust upgrades because of the larger intake valves. Hopefully the engine was rebuilt with stock-like flat-top pistons and not the typical dished rebuilder pistons.
(By the way, it's "0.030 inch over", not .30". Can't bore the typical 305 .30" over.)
Old Jun 5, 2008 | 02:03 PM
nascar2496's Avatar
Engine: 305 tpi
Re: heads
350 cam im not sure of, the kid i bought it from lost the paperwork conveniently. but i do know for a fact its flat top pistons with "0.030" on the top of them. im not too worried about the cam that is in it because i want to upgrade it since im doing all this work. i heard a zz4 or HOT cam works nicely?
Old Jun 5, 2008 | 04:24 PM
five7kid's Avatar
See sig.
The ZZ4 cam only works if the block is a factory roller type.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
