help me pass emissions please
Old Jun 5, 2008 | 04:49 PM
cory's Avatar
Car: 1985 trans am WS6
Engine: 350cam,carb,intake,headers,3"exuast
Transmission: T5,
Axle/Gears: 3.73 posi disks
ok i have a 1985 trans am it has a 305 it has a holley carb edlebrock intake,cam and headers with exaust
i failed everything
HC was 143 im alowed 100
CO was 2.30 im alowed .32
NOx was 809 im alowed 700
i would really apreciate it if someone could help me out
Old Jun 5, 2008 | 05:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Can we assume you mean a universal square-bore Holley, and not a Holley re-manufactured q-jet?
Can we assume non-EGR Edelbrock intake manifold?
Can we assume vacuum-mechanical advance distributor?
Can we assume A.I.R. removed?
Can we assume no catalytic converter?
If we can assume all that, you can assume you're up the perverbal creek without a paddle.
High HC means unburned or partially burned fuel - a "miss", either due to ignition or compression leak. If you haven't already, new plugs, wires, cap and rotor may improve it if it is an ignition issue.
High CO means mixture is too rich. Probably carb adjustment/tuning, possibly choke not fully open.
High NOx means high combustion temperature or pressure. EGR is designed to combat that. If you have EGR, then either the valve isn't working properly, or the passages are clogged. If you don't have EGR, backing off the timing is your only hope.
You may be able to lean out the idle mixture, lean out the jets, and back off the timing, after the ignition tune-up, and get it closer. If you don't have a cat, put one back in.
Old Jun 5, 2008 | 06:14 PM
cory's Avatar
Transmission: T5,
Re: help me pass emissions please
i have a cat and i just connected the pvc valve
Old Jun 6, 2008 | 06:37 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Is it an idle test or dyno test? If it is a dyno test I doubt anything you do cam make you pass.
This is why I am very against removing emission equipment. Every two years I drive up and get a sticker without issue.
Old Jun 6, 2008 | 08:15 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
not sure about connecticut, but maybe it's time to just get it "collectable" or similar tagged and use another car as a daily driver. Otherwise, like everyone said, all you can really do is retard timing and lean the crap out of the carb setup and make sure your ignition system is fully functional. Use regular gas, not high octane and cross your fingers again. Also, make sure you are running at around 200 degrees. Low temps aren't good for emissions tests.
BTW, why would you disconnect the PCV system ? That has nothing to do about performance and keeps your oil from going all acidic.
Old Jun 6, 2008 | 07:53 PM
cory's Avatar
Transmission: T5,
idk about the hole pvc vavle i bought the car like that and had it all plugged up im ganna try to get to pass again tommarow thanks
Old Jun 6, 2008 | 08:59 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It's not likely to pass without a computer controlled fuel system. That's the reason they went to them in the 80s.
Old Jun 7, 2008 | 12:58 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
If you were to make some changes you could get this thing to pass. It depends on what you want.
Old Jun 7, 2008 | 06:22 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
you could always retard your timing a few degrees
Old Jun 7, 2008 | 07:37 PM
89IROKCONVERT's Avatar
go to the junk yard get a smog pump put some fresh air into the exhaust and pass then take it all back off and save it for the next inspection. how much do you love your car?
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
