timing ? need help please.
Old Jun 7, 2008 | 02:28 PM
doug68's Avatar
i have a 84 z28 the veci label says unplug 4 wire connector which i dont see the book says unplug tan wire with black stripe that i cant find 305 motor can anybody tell me where i might find the wire so i cant set my timing i appreciate any help thanks.
Old Jun 7, 2008 | 02:32 PM
chupalupa's Avatar
Car: 1991 z28
Engine: L98 TPI
Transmission: Built 700R4
Axle/Gears: 3.23 posi
Re: timing ? need help please.
i had a gmc that was s'posed to have that mysterious tan/black wire, never found it. I jusr disconnected the knock sensor and timed as usual
Old Jun 7, 2008 | 06:27 PM
89IROKCONVERT's Avatar
look over by the blower motor thats where mine is but yours isnt injected so yours should be vacuum advance if so just unhook vacuum and plug it time it put it back.
Old Jun 8, 2008 | 10:00 AM
doug68's Avatar
mine has that elec control carb or whatever its called.
Old Jun 8, 2008 | 05:16 PM
does it have a vacume line going to the distributor ? if it does there will not be a black and tan wire.
bamaboy0323
Sep 3, 2015 06:07 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
