Harmonic Balancer question
Old Jun 8, 2008 | 08:59 AM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
This is a question that came up in a previous thread on a related topic. I keep seeing conflicting opinions.
Do a 305 TBI and a GM 350 truck motor use the same balancer?
My 91 RS has 350 truck motor and someone told me it has a 305 balancer on it. I don't know anyhting about balancers.
The car does have some vibration, and at idle sometimes I get a loud low hum that seems to reverberate through the entire car. I think I saw somebody refer to a similar hum on here once. Said it was common in 3 rd gens.
Anyway, whats the no sh-- story on balancers? Are they different for the truck motors? Even if they aren't, could a worn balancer be causing the hum?
Old Jun 8, 2008 | 02:30 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Harmonic Balancer question
there are 2 sizes of balancers 6in. and 8in. and they are interchangeable for the 305/350 the only difference is timing tab location... one is at 12oclock and the other is more of a 2oclock posistion...
now this can also be much more complicated depending on the type of balance that was done on the rotating assy. as sometimes elcheapo rebuilders will include the harmonic balancer and flywheel in the actual balance... making it a pain to swap balancers
Old Jun 8, 2008 | 02:40 PM
Engine: 350 TBI
Ok. That actually leaves me a little more confused, at least as to what to do.
Here's how I found out my RS didn't have the original 305 in it: I was trying to set the timing and it was way off. The timing cover has the timing tab at 2 o'clock. Cou;dn't get teh car ro run. We figured out that it was the 350, and eyeballed the timing to 12 o'clock. Car is running good no. So which was correct for a GM truck 350? The timing cover with the tab at 2, or the balancer that needed the tab at 12?
I need to change one or the other so I can time it precisely.
Then of course I have the vibration, so I thought maybe it was hte balancer that is wrong
Old Jun 8, 2008 | 05:13 PM
89IROKCONVERT's Avatar
as long as the balancer matches the tab i dont think it would matter but to be sure i would go with which ever one goes with the motor in this case the large balancer out of the truck
Old Jun 8, 2008 | 05:46 PM
Engine: 350 TBI
so the truck motor should have the 8 in balancer? is that the one that gets timed at 12 o clock?
Old Jun 8, 2008 | 06:00 PM
i just know that the one for the truck is larger in diameter and thinner at least thats the way it looks i once bought one from a junk yard and it was from a truck and wouldn't fit my car thats how i learned the difference.
Old Jun 10, 2008 | 03:02 AM
06andersen's Avatar
i have a 1986 camaro it has a 305 in it and it has bad bad head gaskets so i pulled the motor.. i dont like thr 305 cuz its....slow lol. i have a 327 with camel hump heads that i want to throw in it. i dont have a harmonic balancer for it tho....i know the crank dont have the bolt hole but i want to use the balancer is it possible? i mean also i could drill and tap a hole if i had to????? help please
Old Jun 10, 2008 | 08:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
From the factory, 305's had thin small dampers, thick small dampers, thin large dampers, thick large dampers, 2 o'clock dampers, or 12 o'clock dampers.
From the factory, 350's had thin small dampers, thick small dampers, thin large dampers, thick large dampers, 2 o'clock dampers, or 12 o'clock dampers.
From the factory, cars had thin small dampers, thick small dampers, thin large dampers, thick large dampers, 2 o'clock dampers, or 12 o'clock dampers.
From the factory, trucks had thin small dampers, thick small dampers, thin large dampers, thick large dampers, 2 o'clock dampers, or 12 o'clock dampers.
In short, you can't tell by the damper whether it's 305 or 350, or what type of vehicle it came from.
And, I don't care who you hear call it a "balancer", it's a harmonic damper, not a "balancer".
Regardless of the engine it came from, it will be balanced neutral. Unless it's a factory 400 type damper, or needs one and doesn't have one, it's not the cause of your vibration (unless it's defective, of course).
Old Jun 10, 2008 | 11:46 AM
06andersen's Avatar
so then i guess that still never answered my question can i use the damper from my 86 on my 66?
Last edited by five7kid; Jun 10, 2008 at 04:44 PM. Reason: unnecessary lengthy quote
Old Jun 10, 2008 | 04:43 PM
five7kid's Avatar
No. The 305 is bolt-on, the 327 is press fit. (I didn't answer that part because you weren't the original poster.)
Old Jun 10, 2008 | 05:46 PM
06andersen's Avatar
yah i know that its bolt on... i could dril and tap it and make it bolt on
Old Jun 10, 2008 | 07:25 PM
Engine: 350 TBI
Thanks five7kid. So the bottom line is I don't need to devote anymore thought or effort to the harmonic damper, regardless of which type it is. Right?
Old Jun 10, 2008 | 07:38 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
327 small journal is a press fit a large journal has a bolt.
Old Jun 11, 2008 | 04:55 PM
06andersen's Avatar
you can convery it to a larg jurnal right?? or convert it or put a different one in like one our of a 350 or maybe one that has a bolt hole
Old Jun 11, 2008 | 09:03 PM
Engine: 355
You can't swap a large journal crank into a small journal block.
Old Jun 12, 2008 | 01:04 AM
06andersen's Avatar
whats better small jurnel or larg ones
Old Jun 12, 2008 | 02:35 AM
five7kid's Avatar
It doesn't matter. You're stuck with what you've got.
No bolt means a steel small journal crank.
Old Jun 12, 2008 | 02:49 AM
06andersen's Avatar
yah i know im stuck with it..ijust didnt know if one was better. i know small journals are uncomon
Old Jun 12, 2008 | 03:10 AM
five7kid's Avatar
Small journal 327's were made from 1962 to 1967. The 327 was the bread & butter engine during those years. Steel crank.
Large journal 327's were made from 1968 to 1969. The 350 came out during that time, and the 327 became a lo-po 2bbl base V8 engine. Cast crank.
Other than limited choices with regard to harmonic dampers, the small journal would otherwise be considered the superior and more common crank.
Old Jun 12, 2008 | 12:22 PM
06andersen's Avatar
i was told that i could put the 350 crank in it? i guess i prolly could as long as it was the small journel. i have a few more questions if ur up for it?
Old Jun 12, 2008 | 03:06 PM
five7kid's Avatar
There was no small journal 350 crank. So, you'd either have to have a large journal block, or cut the 350 main journals down to small journal size. Which would probably cost you more than a used 350 shortblock.
(If we keep this off-topic discussion up, I'm going to have to move your posts with the responses to them to a new thread.)
Old Jun 13, 2008 | 01:05 AM
06andersen's Avatar
yah i know i just went out and bought a 4 bolt main 350 so ill prolly just work with that if i have problems with the 327 that i have. for some reason the pistons turn hard i havent gotten the starter in yet but i hope it turns it over. thanks for the help man
Old Nov 5, 2011 | 01:08 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
ok, I have a question. My car was a 305 tbi, now it's a 350 tpi. I know it has the 305 starter, flywheel and 700r4 trans. Now, my problem is when i go to time it. Timing tab is pretty visible on the timing cover. Timing tab appears to be at 1:30. I found TDC with a piston stop. so i remarked the balancer ,but it turns out the new mark i made is right on with the mark originally on the balancer. So, do i have the wrong timing cover? Tdc is coming out to more like 2 o'clock, which is way lower than the timing tab itself! The balancer is a real small one, probably like 6 inches in diameter.
Americanmouse
Sep 7, 2015 12:10 PM
gixxer92
Sep 1, 2015 04:32 PM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
