Need Help buying an alternator.
Old Jun 8, 2008 | 11:14 AM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Transmission: reverse valve
I need an alternator for my car. I have changed them before on other cars, but I do not know a lot about them at all.
I have an 85 T/A 305 TPI and was wondering what amp alternator I should get? Everything is factory except the cd player and 2 10in subs and 1 amp I put in the car. It's not a huge system or anything. I just know that usually you should have a bigger amp alternator depending what systems you have and stuff.
THanks
Old Jun 8, 2008 | 10:24 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Need Help buying an alternator.
THanks
The stock alternator has plenty of output capacity. I wouldn't worry about it.
Old Jun 9, 2008 | 02:55 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Thank you,
I will go ahead and order one from Napa today than. Thanks!
Travis
Old Jun 11, 2008 | 07:28 AM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
aletheian,
Make sure you get the A/C Delco alternator. I messed around with pepboy's prostart and literally exchanged it 5 times (life time warrenty) before I forked over the difference of 30 dollars or so for the A/C version. Its been with me for 4 years now and no problem.
If your amp isn't too much of a draw (300-400 watts) and even if you had a larger amp just get a capacitor either a 1 or 2 farad of course its all relative to the extra draw from your audio system. Remember, always ground your system properly and get the appropriate size power and ground wires.
So in my opinion, I would highly recommend the stock A/C Delco over any other brand and if you need extra juice (when the bass hits your headlights/cluster panel etc dim) then get the appropriate capacitor.
Rabi C.
Old Jun 11, 2008 | 02:29 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
What if you want a chrome alt? What brand do you suggest?
Old Jun 11, 2008 | 02:53 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
I am getting the alternator today. I will ask for AC DELCO.
Old Jun 14, 2008 | 09:34 PM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
you need a compasitor for your amp, for 2 10" subs, i got the 1.2 farad compasitor, i know they are pricey, but dont skimp out. installation is easy. straigt 4g. wire from the battery, to a in line fuse, then to the compasitor, then from the compasitor to the amp. also ground the compasitor, and the amp to eachother. you need a good one with 4 terminals. power in, power out, ground in, ground out. chassis ground into the compasitor, then out of the compasitor to the amp. its simple, but can be a wire mess, use the 4 guage wire tho, it dont let me down, and you really need it. good luck, p m me if you need anything.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
