91 Z horn doesn't work
Old Jun 11, 2008 | 11:04 AM
91Zconvert's Avatar
Car: 91 Z28 ragtop, 88 SS monte
Transmission: auto
i have a 91 Z28 and the horn doesn't work.
yes i checked the fuse.
the rear hatch doesn't work either but the courtesy lights do.
Old Jun 11, 2008 | 04:24 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: 91 Z horn doesn't work
your not going to like this, follow the wires and check continuity threw them. Thats the only way...
Old Jun 12, 2008 | 11:58 AM
Icarus 402001's Avatar
Car: 92RS
Check the wiring connectors under the steering column. They're located above and between your knees when sitting in the driver's seat. I had done some work under there and bumped one unknowingly. I was real relieved to find one of the two loose. I ran a wire tie around each to keep them from coming apart again. Good luck.
Old Jun 12, 2008 | 08:15 PM
Ruiner's Avatar
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
on my car it was the horn switch that was bad, I just ran a wire from the horn relay to a push button on the dash (with the other side grounded), I mounted it in the pop-off panel below the headlight switch
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
