LT1 with bent connecting rod
Old Jun 12, 2008 | 01:02 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Anyone know if an LT1 can be bored out beyond .030 over? Someone I know has a bent rod. I thought I saw that boring LT1s too much is not a good idea (for some reason).
Old Jun 12, 2008 | 02:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: LT1 with bent connecting rod
I think you might be right, i've heard they aren't that friendly to rebuild, not enough cylinder wall to them....
Have to sonic check it to know though
Old Jun 12, 2008 | 07:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
.060" is typically the "limit", just like with most Gen 1 350s. Anything beyond .030 though, get it checked, as Sonix suggested.
Old Jul 3, 2008 | 11:10 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I have connecting rods and pistons in good shape from a Gen 1 350. Will using them in an LT1 block cause a problem?
Old Jul 3, 2008 | 03:35 PM
Air_Adam's Avatar
As long as its from a 1pc rear seal Gen 1 motor, it shouldn't be a problem. Just note that the LT1 rotating assembly was balanced differently from a generic 350, due to the LT1's lightweight pistons. If you use LT1 pistons on a normal Gen 1 crank/rods, it will require balancing. Normal 350 pistons can be used though, as they are dimentionally the same as the LT1 stuff.
Old Jul 3, 2008 | 03:44 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yeah it can usually be bored out more than .030, like adam said I've seen .060 before. Those pistons and rods will work but also like he said, have them all balanced!
Old Jul 4, 2008 | 01:39 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
If I find a set of LT1 pistons and rods they would also need to be balanced since they did not come with this current crankshaft?
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
