Timing on a 87 305
Old Jun 13, 2008 | 02:27 PM
the chief's Avatar
Timing on a 87 305
can some one tell me the what the timming for a 87 305 wit a accel HEI and a edelbrock 600cfm is? the motor is shaking and ideling like it has parkinsons disease
Old Jun 13, 2008 | 11:46 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
Re: timming on a 87 305
aftermarket dizzy.
check around your timing chain cover (right behind the water pump) and find the timing tab.
base timing is beleive is 0 degrees at idle if i remember correctly
you might have installed the distributor wrong if you JUST installed the new dizzy and you are having problems with it now.
check your wires and make sure they are seated correctly (could be a misfire).
might be running lean to the point where the car is not getting enough fuel...
you could have an intake leak...
we need to know WHEN this statred happening.
did you just install the dizzy.
did you just install the carb?
what was the last thing you did to your car .
Old Jun 13, 2008 | 11:51 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
umm i wouldnt recomend 0 degrees for the base timing...i run my 350 at 14 degrees advanced base timing....here is a great article in the tech section...https://www.thirdgen.org/hei
Old Jun 14, 2008 | 01:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Zero degrees is the base timing for the computer controlled system.
Non-computer distributor typically is 8-12 degrees BTDC with the vacuum advance disconnected.
Old Jun 14, 2008 | 10:46 AM
danandamy's Avatar
Car: 86 Camaro
Re: Timing on a 87 305
With the vacume line off the advance I run mine at 12*.
Old Jun 14, 2008 | 07:15 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
yeah i seen that today on a stocker lg4 86 IROC....didnt know u could get IROCs with Lg4s....
Old Jun 14, 2008 | 08:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The base engine for 85-87 IROC's and Z28's is the LG4. The L69 and the TPI are the optional upgrade engines. From 88-89, the TBI is the standard engine for IROC's, and the TPI is the upgrade. From 90-92, TPI is the standard engine. Now you know.
Old Jun 14, 2008 | 08:30 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
14° with Texas' heat? How do you get away with that? Mine would ping at 8° under the same weather (premium gas).
Old Jun 14, 2008 | 10:02 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
well with my 93 octane ive never heard a ping...shes runnin a lil rich though when i lean it out ill probably have to drop back to about 12
Jake_92RS
Jan 28, 2020 10:37 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
justin57
Aug 20, 2015 07:05 PM
